Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI ADS8319IDGST — Даташит
СерияADS8319
МодельADS8319IDGST
Datasheet Texas Instruments ADS8319IDGST
Прецизионный 16-битный SAR с интерфейсом SPI в MSOP-10 10-VSSOP от -40 до 85
ADS8319 16-Bit, 500-kSPS, Serial Interface, Micropower, Miniature, SAR Analog-to-Digital Converter datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 9 дек 2016
  • The IBIS model, Part 2: Determining the total quality of an IBIS model
    PDF, 221 Кб, Файл опубликован: 14 мар 2011
  • Low Power Input and Reference Driver Circuit for ADS8318 and ADS8319
    PDF, 1.5 Мб, Файл опубликован: 24 июн 2009
    The one size fits all approach to operational amplifiers is not effective. Every application has its own specific requirements that must be fulfilled. Appropriate selection of the op amp that drives an analog-to-digital converter (ADC) in a low-power application is a critical step. Most available low-power op amps trade off low-power features with other parameters such as bandwidth, settling t
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS8319IDGST
Политика конфиденциальности
