Datasheet Texas Instruments MSP430F6747IPEUR — Даташит
СерияMSP430F6747
МодельMSP430F6747IPEUR
MSP430F677x, MSP430F676x, MSP430F674x Микроконтроллер смешанных сигналов 128-LQFP от -40 до 85
MSP430F677x, MSP430F676x, MSP430F674x Polyphase Metering SoCs datasheet
PDF, 1.9 Мб, Версия: D, Файл опубликован: 19 дек 2013
Pin128
Package TypePEU
Industry STD TermLQFP
JEDEC CodeR-PQFP-G
Package QTY750
МаркировкаF6747
Width (мм)14
Length (мм)20
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
ADCADC10 - 6ch,SigmaDelta24 - 4ch
AESAES128
Active Power346.8 uA/MHz
Additional FeaturesLCD,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset,IrDA
BSLUART
CPUMSP430
DMA3
Featuredf6
Тактовая частота25 МГц
GPIO Pins90
I2C2
Max VCC3.6
Min VCC1.8
Multiplier32x32
Non-volatile Memory256 KB
Package GroupLQFP
Package Size: mm2:W x L100LQFP: 256 mm2: 16 x 16(LQFP) PKG
RAM32 KB
SPI6
Special I/ON/A
Standby Power2.9 LPM3-uA
Timers - 16-bit4
UART4
Wakeup Time5 us
  • Development Kits: MSP-TS430PEU128
    MSP-TS430PEU128 - 128-pin Target Development Board for MSP430F6x MCUs
  • Evaluation Modules & Boards: EVM430-F6779
    EVM430-F6779 - 3 Phase Electronic Watt-Hour EVM for Metering
  • Development Kits: MSP-FET430U128
    128-pin Target Development Board and MSP-FET Programmer Bundle for MSP430F6x MCUs
    MSP EnergyTrace Technology
  • Implementation of a Three-Phase Electronic Watt-Hour Meter Using MSP430F677x(A) (Rev. G)
    PDF, 2.4 Мб, Версия: G, Файл опубликован: 5 авг 2015
    This application report describes the implementation of a three-phase electronic electricity meter using the Texas Instruments MSP430F677x(A) metering processor. This application report includes the necessary information with regard to metrology software, hardware procedures for this single-chip implementation.
  • Using TI’s DLMS COSEM Library
    PDF, 74 Кб, Файл опубликован: 12 ноя 2013
    This application report describes in detail the usage of DLMS COSEM library developed by Texas Instruments for customers who use TI's microcontrollers in metering applications. The library is provided as object coded with a configuration file for ease of use. The library can be obtained by contacting the regional sales and marketing offices. The customer will have to sign an SLA before getting acc
  • Differences Between MSP430F67xx and MSP430F67xxA Devices
    PDF, 3.5 Мб, Файл опубликован: 30 мар 2015
    This application report describes the enhancements of the MSP430F67xxA devices from the non-A MSP430F67xx devices. In the course of this application report, the MSP430F67xx errata that are fixed in the MSP430F67xxA and the additional features added to the MSP430F67xxA devices are discussed. In addition, metrology results are compared to further show that the changes implemented in the MSP430F67xxA
  • Designing With MSP430 and Segment LCDs (Rev. A)
    PDF, 2.1 Мб, Версия: A, Файл опубликован: 20 июл 2015
    Segment liquid crystal displays (LCDs) are needed to provide information to users in a wide variety of applications from smart meters to electronic shelf labels (ESL) to medical equipment. Several MSP430в„ў microcontroller families include built-in low-power LCD driver circuitry that allows the MSP430 MCU to directly control the segmented LCD glass. This application note helps explain how segmented
  • Migrating from the MSP430F5xx,F6xx Family to the MSP430FR58xx/FR59xx/68xx Family (Rev. D)
    PDF, 151 Кб, Версия: D, Файл опубликован: 3 ноя 2016
    This application report helps enable easy migration from MSP430F5xx and MSP430F6xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight differences between the
  • General Oversampling of MSP ADCs for Higher Resolution (Rev. A)
    PDF, 551 Кб, Версия: A, Файл опубликован: 1 апр 2016
    Multiple MSP ultra-low-power microcontrollers offer analog-to-digital converters (ADCs) to convert physical quantities into digital numbers, a function that is widely used across numerous applications. There are times, however, when a customer design demands a higher resolution than the ADC of the selected MSP can offer. This application report, which is based on the previously-published Oversampl
  • MSP Code Protection Features
    PDF, 752 Кб, Файл опубликован: 7 дек 2015
    MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
  • ESD Diode Current Specification
    PDF, 520 Кб, Файл опубликован: 7 дек 2015
    This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F5x/6x
На английском языке: Datasheet Texas Instruments MSP430F6747IPEUR
