Datasheet Texas Instruments UCC39411DG4 — Даташит
СерияUCC39411
МодельUCC39411DG4
Синхронный повышающий преобразователь малой мощности 8-SOIC от 0 до 70
Low Power Synchronous Boost Converter datasheet
PDF, 1.2 Мб, Версия: E, Файл опубликован: 20 июл 2005
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY7575
CarrierTUBETUBE
МаркировкаUCC39411
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Duty Cycle(Max)100 %
Iq(Typ)0.048 мА
Regulated Outputs1
Switch Current Limit(Min)0.385 A
Switch Current Limit(Typ)0.55 A
Switching Frequency(Max)500 kHz
Switching Frequency(Min)500 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)1 В
Vout(Max)5 В
Vout(Min)2 В
  • DN-97 UCC39411 Low-Power Synchronous Boost Converter, Evaluation Kit, Schematic
    PDF, 34 Кб, Файл опубликован: 5 сен 1999
    The UCC39411/2/3 Evaluation Kit allows the designer to evaluate the performance of the UCC39411/2/3 Low-power Synchronous Boost Converter in a typical application circuit. The schematic for the evaluation kit is provided. The kit can be configured to evaluate any version of the UCC39411 family.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: UCC39411 (5)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments UCC39411DG4
