Datasheet Texas Instruments LMC6492BEMX — Даташит
СерияLMC6492
МодельLMC6492BEMX
Двойной операционный усилитель CMOS Rail-to-Rail с входом и выходом 8-SOIC от -40 до 125
LMC6492 Dual/LMC6494 Quad CMOS Rail-to-Rail Input and Output Op Amp datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 22 мар 2013
27 предложений от 16 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMC6492BEMX/NOPB Operational Amplifier, Dual, 2 Amplifier, 1.5MHz, 1.3V/µs, 2.5V to 15V, SOIC, 8Pins
LMC6492BEMX/NOPB
62 ₽
LMC6492BEMX
65 ₽
LMC6492BEMX
101 ₽
LMC6492BEMX
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
МаркировкаLMC6492BEM
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Рекомендуемая замена
ReplacementLMC6492BEMX/NOPB
Replacement CodeS
Additional FeaturesN/A
Approx. Price (US$)1.05 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)63
CMRR(Typ)(dB)82
GBW(Typ)(MHz)1.5
Input Bias Current(Max)(pA)1.5
Iq per channel(Max)(mA)0.88
Iq per channel(Typ)(mA)0.5
Number of Channels(#)2
Offset Drift(Typ)(uV/C)1
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)22
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailIn
Out
Slew Rate(Typ)(V/us)1.3
Total Supply Voltage(Max)(+5V=5, +/-5V=10)15.5
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.5
Vn at 1kHz(Typ)(nV/rtHz)37
Vos (Offset Voltage @ 25C)(Max)(mV)3
RoHSНе совместим
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
На английском языке: Datasheet Texas Instruments LMC6492BEMX
