Datasheet Texas Instruments LM3S1H11-IQC80-A2T — Даташит
СерияLM3S1H11
МодельLM3S1H11-IQC80-A2T
Микроконтроллер Stellaris LM3S 100-LQFP от -40 до 85
Stellaris LM3S1H11 Microcontroller Data Sheet datasheet
PDF, 5.8 Мб, Версия: C, Файл опубликован: 3 июл 2014
7 предложений от 7 поставщиков
IC MCU 32BIT 512KB FLASH 100LQFP. ARM® Cortex®-M3 Stellaris® ARM® Cortex®-M3S 1000 Microcontroller IC 32-Bit 80MHz 512KB (512K x 8) FLASH...
Hi-Tech Circuit Group
LM3S1H11-IQC80-A2T
LM3S1H11-IQC80-A2T
LM3S1H11-IQC80-A2T
МосЧип
LM3S1H11-IQC80-A2T
Pin100100
Package TypePZPZ
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаIQC80LM3S1H11
Width (мм)1414
Length (мм)1414
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместим
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
LM3S1H11IQC80A2T, LM3S1H11 IQC80 A2T
На английском языке: Datasheet Texas Instruments LM3S1H11-IQC80-A2T
