Datasheet Texas Instruments 5962-9959901Q2A — Даташит
СерияTHS4051M
Модель5962-9959901Q2A
Высокоскоростной усилитель 70 МГц 20-LCCC от -55 до 125
Микросхема Операционный усилитель, OP Amp Single Volt Fdbk 16.5V/33V 20Pin LCCC Tube
5962-9959901Q2A
3 444 ₽
5962-9959901Q2A
4 630 ₽
5962-9959901Q2A
5962-9959901Q2A
Pin202020
Package TypeFKFKFK
Industry STD TermLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY111
CarrierTUBETUBETUBE
МаркировкаTHS4051MFKB5962-9959901Q2A
Width (мм)8.898.898.89
Length (мм)8.898.898.89
Thickness (мм)1.831.831.83
Pitch (мм)1.271.271.27
Max Height (мм)2.032.032.03
Additional FeaturesN/A
АрхитектураVoltage FB
Bipolar
CMRR(Min)(dB)70
CMRR(Typ)(dB)100
GBW(Typ)(MHz)70
IIB(Max)(pA)6000000
Iq per channel(Max)(mA)10.5
Iq per channel(Typ)(mA)8.5
Number of Channels(#)1
Offset Drift(Typ)(uV/C)15
Operating Temperature Range(C)-55 to 125
Output Current(Typ)(mA)100
Package GroupLCCC
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
Rail-to-RailNo
RatingMilitary
Slew Rate(Typ)(V/us)240
Total Supply Voltage(Max)(+5V=5, +/-5V=10)32
Total Supply Voltage(Min)(+5V=5, +/-5V=10)9
Vn at 1kHz(Typ)(nV/rtHz)14
Vos (Offset Voltage @ 25C)(Max)(mV)10
RoHSTBD
  • Semiconductors > Space & High Reliability > Amplifier > Operational Amplifiers
59629959901Q2A, 5962 9959901Q2A
На английском языке: Datasheet Texas Instruments 5962-9959901Q2A
