Datasheet Texas Instruments TPS61180RTER — Даташит
| Серия | TPS61180 |
| Модель | TPS61180RTER |
Драйвер белого светодиода 1,5 А для ноутбуков 16-WQFN от -40 до 85
WLED DRIVER FOR NOTEBOOK DISPLAY. datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 11 апр 2013
Купить TPS61180RTER на РадиоЛоцман.Цены — от 27 до 293 ₽33 предложений от 18 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами | |||
| TPS61180RTER Texas Instruments | 27 ₽ | ||
| TPS61180RTER Rochester Electronics | 85 ₽ | ||
| TPS61180RTER Texas Instruments | от 95 ₽ | ||
| TPS61180RTER | по запросу | ||
| Pin | 16 |
| Package Type | RTE |
| Industry STD Term | WQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | CCG |
| Width (мм) | 3 |
| Length (мм) | 3 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
| Количество каналов | 6 |
| Duty Cycle(Max) | 94 % |
| LED | 60 |
| LED Current Per Channel | 25 мА |
| Package Group | WQFN |
| Package Size: mm2:W x L | 16WQFN: 9 mm2: 3 x 3(WQFN) PKG |
| Peak Efficiency | 90 % |
| Rating | Catalog |
| Shutdown Current(Typ) | 16 uA |
| Special Features | Load Disconnect During Shutdown |
| Switching Frequency(Max) | 1000 kHz |
| Topology | Boost |
| Тип | Inductive |
| Vin(Max) | 24 В |
| Vin(Min) | 5 В |
| Vout(Max) | 39 В |
| Vout(Min) | 5 В |
- Extending the Input Voltage Range of the TPS6116x/8x/9x WLED DriversPDF, 124 Кб, Файл опубликован: 12 авг 2009
The TPS6116x, TPS6118x and TPS6119x WLED driver and TPS6117x boost converter integrated circuits (IC) can operate with different input voltages, one powering the IC itself and the other powering the boost power stage. This application report explains various options on how to use the WLED drivers with split power rails. This allows these LED drivers to be used in applications where the available - Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS61180 (4)
- TPS61180RTER TPS61180RTERG4 TPS61180RTET TPS61180RTETG4
- Semiconductors > Power Management > LED Driver > Backlight LED Driver
