Datasheet Texas Instruments THS4120CDGN — Даташит
СерияTHS4120
МодельTHS4120CDGN
3,3 В, 100 МГц, 43 В/мкс, полностью дифференциальный КМОП-усилитель с отключением 8-MSOP-PowerPAD 0–70
THS4120, THS4121: High-Speed Fully Differential-I/O Amplifier datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 13 окт 2004
23 предложений от 19 поставщиков
THS4120CDGN
192 ₽
Зенер
Россия и страны ТС
THS4120CDGN
от 805 ₽
THS4120CDGN
от 815 ₽
THS4120CDGN
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Package QTY80
МаркировкаARL
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic79 dBc
3rd Harmonic93 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураCMOS,Fully Differential,Voltage FB
BW @ Acl100 МГц
CMRR(Min)64 дБ
CMRR(Typ)96 дБ
GBW(Typ)100 МГц
Input Bias Current(Max)1.2 pA
Iq per channel(Max)13.5 мА
Iq per channel(Typ)11 мА
Количество каналов1
Offset Drift(Typ)25 uV/C
Output Current(Typ)25 мА
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) PKG
Rail-to-RailIn to V+,Out
Slew Rate(Typ)55 V/us
Total Supply Voltage(Max)3.5 +5V=5, +/-5V=10
Total Supply Voltage(Min)3 +5V=5, +/-5V=10
Vn at 1kHz(Typ)16 нВ/rtГц
Vn at Flatband(Typ)5.4 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)8 мВ
  • Evaluation Modules & Boards: THS4120EVM
    THS4120 Evaluation Module
  • Evaluation Modules & Boards: THS4140EVM
    THS4140EVM Evaluation Module
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
На английском языке: Datasheet Texas Instruments THS4120CDGN
