Datasheet Texas Instruments ADS807EG4 — Даташит
Серия | ADS807 |
Модель | ADS807EG4 |
12-разрядный АЦП, 53 MSPS, входы SE/Diff с диапазоном от 2 до 3 В (размах), внутреннее/внешнее задание, индикатор выхода за пределы диапазона 28-SSOP от -40 до 85
ADS807: 12-Bit, 53MHz Sampling Analog-To-Digital Converter (Rev. A)
PDF, 853 Кб, Версия: A, Файл опубликован: 11 июн 2002
Pin | 28 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | ADS807E |
Width (мм) | 5.3 |
Length (мм) | 10.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
# Input Channels | 1 |
Analog Input BW(MHz) | 270 |
Approx. Price (US$) | 13.66 | 1ku |
Архитектура | Pipeline |
DNL(Max)(+/-LSB) | 1 |
ENOB(Bits) | 0.5 |
INL(Max)(+/-LSB) | 2 |
Input Range | 2V / 3V (p-p) |
Interface | Parallel CMOS |
Operating Temperature Range(C) | -40 to 85 |
Package Group | SSOP |
Package Size(mm2=WxL) | 28SSOP: 80 mm2: 7.8 x 10.2 |
Power Consumption(Typ)(mW) | 335 |
Rating | Catalog |
Reference Mode | Int Ext |
Resolution(Bits) | 12 |
SFDR(dB) | 82 |
SINAD(dB) | 69 |
SNR(dB) | 69 |
Sample Rate (max)(SPS) | 53MSPS |
Бессвинцовая технология (Pb Free) | Да |
- Evaluation Modules & Boards: TSW2200EVM
TSW2200EVM: Low Cost Portable Power Supply
- CDCE62005 as Clock Solution for High-Speed ADCsPDF, 805 Кб, Файл опубликован: 4 сен 2008
TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527, which is capable of sampling up to 210 MSPS. To realize the full potential of thes - Smart Selection of ADC/DAC Enables Better Design of Software-Defined RadioPDF, 376 Кб, Файл опубликован: 28 апр 2009
This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs - Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies - Phase Noise Performance and Jitter Cleaning Ability of CDCE72010PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the refe - CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital ConvertersPDF, 424 Кб, Файл опубликован: 8 июн 2008
Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed, high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483, which is capable of - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
AB-082 Principles of Data Acquisition and Conversion - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
AB-084 Analog-to-Digital Grounding Practices Affect System Performance - Interleaving Analog-to-Digital ConvertersPDF, 64 Кб, Файл опубликован: 2 окт 2000
It is tempting when pushing the limits of analog-to-digital conversion to consider interleaving two or more converters to increase the sample rate. However, such designs must take into consideration s - A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (ΔΣ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specificati - What Designers Should Know About Data Converter DriftPDF, 95 Кб, Файл опубликован: 2 окт 2000
Exactly how inaccurate will a change in temperature make an analog-to-digital or digital-to-analog converter? As designers are well aware, a 12-bit device may provide a much lower accuracy at its oper
Серия: ADS807 (3)
- ADS807E ADS807E/1K ADS807EG4
- Semiconductors > Data Converters > Analog to Digital Converter > High Speed ADC (>10MSPS)
