Datasheet Texas Instruments BQ4845S-A4TR — Даташит
Серия | BQ4845 |
Модель | BQ4845S-A4TR |
RTC IC W Управление NVSRAM, сторожевой таймер, сброс uP, прерывания и предупреждение о низком заряде батареи 28-SOIC 0–70
Parallel RTC With CPU Supervisor datasheet
PDF, 1.6 Мб, Файл опубликован: 5 сен 1999
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 28 | 28 |
Package Type | DW | DW |
Industry STD Term | SOIC | SOIC |
Package QTY | 1000 | 1000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | 4845S | -A4 |
Width (мм) | 7.5 | 7.5 |
Length (мм) | 17.9 | 17.9 |
Thickness (мм) | 2.35 | 2.35 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 2.65 | 2.65 |
- U-502 Time-Base Oscillator for RTC ICPDF, 313 Кб, Файл опубликован: 5 сен 1999
Time-Base Oscillator for RTC ICs.The operation of the time-base oscillator is critical to the timekeeping functions of the bq3285, bq4285, and bq4845 series of real-time-clocks (RTCs). This application note describes some basic characteristics of the piezoelectric crystal and the on-chip crystal oscillator circuitry designed into these RTC series. It also includes suggestions for achieving timek - U-500 Using the bq4845 for a Low-Cost RTC/NVSRAM SubsystemPDF, 332 Кб, Файл опубликован: 5 сен 1999
Using the bq4845 for a Low-Cost RTC/NVSRAM Subsystem.The bq4845 combines on one IC a low-power real-time clock (RTC), a microcontroller supervisor, and a nonvolatile control circuit for static RAM. The part is the basis of a low-cost, reliable RTC plus nonvolatile SRAM subsystem for many embedded applications. This application note discusses the key aspects of bq4845 operation: component sele
Серия: BQ4845 (9)
- Semiconductors > Clock and Timing > Real-time Clocks
BQ4845SA4TR, BQ4845S A4TR
