Datasheet Texas Instruments V62/04715-01XE — Даташит
СерияSN74LVTH16543-EP
МодельV62/04715-01XE
Усовершенствованный продукт 16-битный зарегистрированный трансивер с напряжением 3,3 В и выходами с 3 состояниями 56-TSSOP от -40 до 85
SN74LVTH16543-EP datasheet
PDF, 298 Кб, Версия: B, Файл опубликован: 16 июн 2006
Pin56
Package TypeDGG
Industry STD TermTSSOP
Package QTY2000
МаркировкаLH16543EP
Width (мм)6.1
Length (мм)14
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
Bits16
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Package GroupTSSOP
Package Size: mm2:W x L56TSSOP: 113 mm2: 8.1 x 14(TSSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
V62/0471501XE, V62/04715 01XE
На английском языке: Datasheet Texas Instruments V62/04715-01XE
Публикации по теме
