Datasheet Texas Instruments LM3401MMX/NOPB — Даташит
СерияLM3401
МодельLM3401MMX/NOPB
Гистерезисный PFET-контроллер для привода светодиодов высокой мощности 8-VSSOP от -40 до 125
LM3401 Hysteretic PFET Controller for High Power LED Drive datasheet
PDF, 1.1 Мб, Версия: C, Файл опубликован: 2 май 2013
Package TypeDGK
Industry STD TermVSSOP
Package QTY3500
МаркировкаSNHB
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Dimming MethodPWM
Входное напряжениеDC/DC Type
Iout(Max)1 A
Iq(Typ)1.05 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown
Switching Frequency(Max)1500 kHz
Switching Frequency(Min)100 kHz
TopologyBuck
ТипInductive
Vin(Max)35 В
Vin(Min)4.5 В
Vout(Max)33 В
Vout(Min)0.2 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3401-MR16DEMO
    LM3401 MR16 Bulb Reference Design for Non-Dimming & Dimming LED Applications
  • Evaluation Modules & Boards: LM3401EVAL
    LM3401 Hysteretic PFET Controller for High Power LED Drive Evaluation Module
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3401 (2)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3401MMX/NOPB
