Datasheet Texas Instruments AM26LS33ACDR — Даташит
| Серия | AM26LS33A |
| Модель | AM26LS33ACDR |
Четверной дифференциальный линейный приемник 16-SOIC от 0 до 70
AM26LS32Ax, AM26LS33Ax Quadruple Differential   Line Receivers datasheet
PDF, 1.4 Мб, Версия: F, Файл опубликован: 19 сен 2016
 Купить AM26LS33ACDR на РадиоЛоцман.Цены — от 10 до 88 ₽38 предложений от 17 поставщиков Чип интерфейса, TEXAS INSTRUMENTS AM26LS33ACDR RS422 / RS423 Differential Line Receiver IC, 4 Drivers, 4.75V to 5.25V, SOIC-16  | |||
| AM26LS33ACDR Texas Instruments  | 26 ₽ | ||
| AM26LS33ACDR Texas Instruments  | от 37 ₽ | ||
| AM26LS33ACDR Texas Instruments  | 70 ₽ | ||
| AM26LS33ACDR Texas Instruments  | по запросу | ||
| Pin | 16 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | 26LS33AC |
| Width (мм) | 3.91 |
| Length (мм) | 9.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| ICC(Max) | 70 мА |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | SOIC |
| Rating | Catalog |
| Supply Voltage(s) | 5 В |
- Wave Solder Exposure of SMT PackagesPDF, 206 Кб, Файл опубликован: 9 сен 2008
It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
Серия: AM26LS33A (7)
- Semiconductors > Interface > RS-485/RS-422
