Datasheet Texas Instruments S5LS20216ASPGEMEP — Даташит
| Серия | TMS570LS20216-EP |
| Модель | S5LS20216ASPGEMEP |
Усовершенствованный продукт: 16- и 32-битный флэш-микроконтроллер RISC 144-LQFP от -55 до 125
TMS570LS20206-EP, TMS570LS20216-EP 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 967 Кб, Версия: A, Файл опубликован: 2 авг 2012
Купить S5LS20216ASPGEMEP на РадиоЛоцман.Цены — от 1 281 до 4 436 ₽10 предложений от 10 поставщиков IC MCU 32BIT 2MB FLASH 144LQFP. ARM® Cortex®-R4F HerculesTM TMS570 ARM® Cortex®-R Microcontroller IC 16/32-Bit 140MHz 2MB (2M x 8)... | |||
| S5LS20216ASPGEMEP Texas Instruments | 1 281 ₽ | ||
| S5LS20216ASPGEMEP Texas Instruments | 3 697 ₽ | ||
| S5LS20216ASPGEMEP Texas Instruments | 4 436 ₽ | ||
| S5LS20216ASPGEMEP Texas Instruments | по запросу | ||
| Pin | 144 | 144 |
| Package Type | PGE | PGE |
| Industry STD Term | LQFP | LQFP |
| JEDEC Code | S-PQFP-G | S-PQFP-G |
| Package QTY | 60 | 60 |
| Carrier | TUBE | TUBE |
| Маркировка | TMS570LS | S20216ASPGEMEP |
| Width (мм) | 20 | 20 |
| Length (мм) | 20 | 20 |
| Thickness (мм) | 1.4 | 1.4 |
| Pitch (мм) | .5 | .5 |
| Max Height (мм) | 1.6 | 1.6 |
- Sharing Exception Vectors on Herculesв„ў Based MicrocontrollersPDF, 238 Кб, Файл опубликован: 27 мар 2017
Some applications require sharing the exception vectors between different applications, like a bootloader and the main application (firmware). This application report describes a software-based approach to move the exception vector table from the flash into the SRAM, to allow for a flexible assignment scheme and ultimately sharing of the exception vectors. - High Speed Serial Bus Using the MibSPIP Module on Hercules-Based MCUsPDF, 804 Кб, Файл опубликован: 22 апр 2016
This application report describes how the Multi-Buffered Serial Peripheral Interface Module (MibSPIP) and the DMA modules found on many devices of the Hercules MCU family can be used to autonomously transfer data from and into the device embedded RAM. In addition to this, the parallel pin option of the MibSPIP module will be covered and used to increase the speed of the SPI link. This technique co - Using the CRC Module on Herculesв„ў-Based MicrocontrollersPDF, 113 Кб, Файл опубликован: 4 авг 2016
This application report describes how the to use the embedded CRC module found on all Hercules devices, as well as how to calculate a signature for non-volatile memory with the TI ARMВ® Code Gen Tools Linker. - Triangle/Trapezoid Wave Generation Using PWM With Hercules N2HETPDF, 476 Кб, Файл опубликован: 1 май 2015
This application report illustrates how to generate various forms of triangle and trapezoid waves using the versatile programmable high-end timer (N2HET). The examples can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET registers as well as basic system s - Sine Wave Generation Using PWM With Hercules N2HET and HTUPDF, 371 Кб, Файл опубликован: 12 май 2015
This application report illustrates how to generate sine waves using the versatile programmable high-end timer (N2HET) and its companion data transfer unit (HTU). The code example can be run in either the Hercules hardware development kit (HDK) or the Launchpadв„ў development kit. The application report shows the N2HET program examples, the steps to setting up the N2HET and HTU registers as we
Серия: TMS570LS20216-EP (4)
- S5LS20216ASGWTMEP S5LS20216ASPGEMEP V62/12622-02XE V62/12622-02YE
- Semiconductors > Space & High Reliability > Microcontroller > Performance MCU > Safety Products
