Datasheet Texas Instruments TPS65132WRVCT — Даташит
СерияTPS65132
МодельTPS65132WRVCT
Преобразователь с разделенной шиной с двойным выходом (биполярный) Стабилизатор SIMO для общих приложений с двойным питанием 20-WQFN от -40 до 85
TPS65132 Single Inductor - Dual Output Power Supply datasheet
PDF, 2.9 Мб, Версия: H, Файл опубликован: 28 окт 2016
Pin20
Package TypeRVC
Industry STD TermWQFN
JEDEC CodeR-PQFP-N
Package QTY250
CarrierSMALL T&R
Маркировка65132YA
Width (мм)4
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Iout(Max)0.15 A
Iq(Typ)0.54 мА
Package GroupWQFN
Switching Frequency(Max)2250 kHz
Switching Frequency(Min)1350 kHz
TopologySplit-Rail
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.5 В
Vout(Max)6 В
Vout(Min)4 В
Vout2(Max)-4 В
Vout2(Min)-6 В
  • Evaluation Modules & Boards: TPS65132BEVM
    TPS65132B Dual Output LCD Bias for Smartphones Evaluation Module
  • Evaluation Modules & Boards: TPS65132LEVM-711
    TPS65132L Single Inductor - Dual Output Power Supply Evaluation Module
  • Evaluation Modules & Boards: TPS65132WEVM-669
    TPS65132W Single Inductor Dual Output Power Supply Evaluation Module
  • Evaluation Modules & Boards: TPS65132SEVM-866
    TPS65132S Evaluation Module: Single Inductor - Dual Output Positive and Negative Power Supply
  • Understanding Undervoltage Lockout in Power Devices (Rev. A)
    PDF, 90 Кб, Версия: A, Файл опубликован: 19 сен 2018
    Many integrated circuits include an undervoltage lockout (UVLO) function to disable the device at low supply voltages. Below the minimum supply voltage the function and performance of a device may be undefined making it impossible to predict system behavior. This application note explains how to correctly understand the undervoltage lockout specification in the data sheets of TI's power products.
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost, Inverting or Split-Rail Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS65132WRVCT
