Datasheet Texas Instruments TPS61107PWG4 — Даташит
СерияTPS61107
МодельTPS61107PWG4
Преобразователь с двумя выходами (Boost DC/DC + LDO) для одно-/двухэлементных приложений 20-TSSOP от -40 до 85
TPS6110x - Dual-Output, Single-Cell Boost Converters datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 15 апр 2004
Pin20
Package TypePW
Industry STD TermTSSOP
Package QTY70
МаркировкаTPS61107
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
  • Evaluation Modules & Boards: TPS61100EVM-216
    TPS61100 Evaluation Module
  • Evaluation Modules & Boards: TPS61107EVM-216
    TPS61107 Evaluation Module
  • Evaluation Modules & Boards: TPS61103EVM-216
    TPS61103 Evaluation Module
  • Evaluation Modules & Boards: TPS61106EVM-216
    TPS61106 Evaluation Module
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
Серия: TPS61107 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61107PWG4
