Datasheet Texas Instruments SN74AS1034ADE4 — Даташит
Серия | SN74AS1034A |
Модель | SN74AS1034ADE4 |
Шестигранные драйверы 14-SOIC от 0 до 70
Hex Drivers datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 1 янв 1995
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | AS1034A |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 6 |
F @ Nom Voltage(Max) | 125 Mhz |
ICC @ Nom Voltage(Max) | 0.014 мА |
Рабочий диапазон температур | от 0 до 70 C |
Output Drive (IOL/IOH)(Max) | -48/48 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 6 нс |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74AS1034A (5)
- SN74AS1034AD SN74AS1034ADE4 SN74AS1034ADG4 SN74AS1034ADR SN74AS1034AN
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
