Datasheet Texas Instruments THS0842IPFB — Даташит
СерияTHS0842
МодельTHS0842IPFB
Двухканальный 8-битный аналого-цифровой преобразователь (АЦП) с быстродействием 40 MSPS 48-TQFP от -40 до 85
Dual-Input, 8-Bit, 40 MSPS, Low-Power ADC w/ Single or Dual Parallel Bus Output datasheet
PDF, 503 Кб, Версия: A, Файл опубликован: 10 авг 2000
30 предложений от 18 поставщиков
Микросхема Преобразователь AD, TEXAS INSTRUMENTS THS0842IPFB Analog to Digital Converter, 8Bit, 40MSPS, Single, 3V, 3.6V, TQFP
THS0842IPFB
361 ₽
THS0842IPFB
от 3 177 ₽
Hi-Tech Circuit Group
THS0842IPFB
ТаймЧипс
THS0842IPFB
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierJEDEC TRAY (10+1)
МаркировкаTJ0842
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
# Input Channels2
Analog Input BW600 МГц
АрхитектураPipeline
DNL(Max)2 +/-LSB
DNL(Typ)0.7 +/-LSB
ENOB6.8 Bits
INL(Max)2.2 +/-LSB
INL(Typ)1.5 +/-LSB
Input BufferNo
Input Range1.3 Vp-p
InterfaceParallel CMOS
Package GroupTQFP
Package Size: mm2:W x L48TQFP: 81 mm2: 9 x 9(TQFP) PKG
Power Consumption(Typ)320 mW
Reference ModeExt,Int
Разрешение8 Bits
SFDR52 дБ
SINAD43.3 дБ
SNR42.7 дБ
Sample Rate(Max)40 MSPS
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
Серия: THS0842 (1)
  • THS0842IPFB
  • Semiconductors > Data Converters > Analog-to-Digital Converters (ADCs) > High Speed ADCs (>10MSPS)
На английском языке: Datasheet Texas Instruments THS0842IPFB
