Datasheet Texas Instruments THS6043IPWPR — Даташит
СерияTHS6043
МодельTHS6043IPWPR
Драйвер линии ADSL CPE, 350 мА, +/-12 В с отключением 14-HTSSOP от -40 до 85
350 mA +/-12V ADSL CPE Line Drivers datasheet
PDF, 1.6 Мб, Версия: G, Файл опубликован: 11 дек 2001
Микросхема Операционный усилитель, 350mA, +/-12V ADSL CPE Line Driver with Shutdown 14-HTSSOP -40℃ to 85℃
THS6043IPWPR
386 ₽
THS6043IPWPR
395 ₽
THS6043IPWPR
656 ₽
Зенер
Россия и страны ТС
THS6043IPWPR
от 1 185 ₽
Pin14
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаHS6043I
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
2nd Harmonic67 dBc
3rd Harmonic96 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesShutdown
АрхитектураCurrent FB
BW @ Acl120 МГц
CMRR(Min)59 дБ
CMRR(Typ)68 дБ
GBW(Typ)120 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)10.5 мА
Iq per channel(Typ)8.2 мА
Количество каналов2
Offset Drift(Typ)20 uV/C
Output Current(Typ)350 мА
Package GroupHTSSOP
Package Size: mm2:W x L14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)1400 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)2.4 нВ/rtГц
Vn at Flatband(Typ)2.2 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)16 мВ
  • Evaluation Modules & Boards: THS6043EVM
    THS6043 Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
  • Wireline Data Transmission and Reception
    PDF, 191 Кб, Файл опубликован: 27 янв 2010
    Many types of wires are widely used to transmit data. Specifically, Category 3 and Category 5 (Cat3 and Cat5e, respectively)—also known as unshielded twisted pair or UTP lines—are now recommended for new telephone installations. Coaxial (coax) cables are used to distribute cable television (CATV) signals throughout a home. #12 and #14 American wire gauge (AWG) electric power distribution wire is a
На английском языке: Datasheet Texas Instruments THS6043IPWPR
