Datasheet Texas Instruments TPS61151DRCT — Даташит
СерияTPS61151
МодельTPS61151DRCT
Двойной переключатель, 2x 27 В, 700 мА, повышающий преобразователь 1,2 МГц с одним индуктором, белый светодиодный дайвер (до 2x6) 10-VSON от -40 до 85
TPS6115x Dual-Output Boost WLED Driver Using Single Inductor datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 30 ноя 2015
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаBRH
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Количество каналов2
Duty Cycle(Max)93 %
LED12
LED Current Per Channel23 мА
Package GroupVSON
Package Size: mm2:W x L10VSON: 9 mm2: 3 x 3(VSON) PKG
Peak Efficiency85 %
Shutdown Current(Typ)1.5 uA
Special FeaturesSynchronous Rectification
Switching Frequency(Max)1200 kHz
TopologyBoost
ТипInductive
Vin(Max)6 В
Vin(Min)3 В
Vout(Max)27 В
Vout(Min)2.5 В
  • Evaluation Modules & Boards: TPS61150EVM-150
    TPS61150EVM Evaluation Module
  • TPS61150 Dual Output Boost Converter Drive Up to 14 WLED Keypad LCD Backlight
    PDF, 70 Кб, Файл опубликован: 5 июл 2006
    The TPS61150/1 is a high-frequency boost converter with two regulated current outputs for driving white light-emitting diodes (WLED). The reference design and applications examples in this document show the TPS61150 driving up to 14 WLEDs, a keypad, and a LCD backlight application. The two current outputs are ideal for driving WLED backlight for the sub and main displays in clamshell phones.
  • Analog PWM Dimming in White-LED Drivers
    PDF, 539 Кб, Файл опубликован: 21 дек 2016
    Pulse-width modulation (PWM) is a common type of dimming used to adjust the current in white-LEDdriver devices. PWM dimming takes a rectangle waveform with variable positive duty cycle (D) and adjuststhe LED current proportionally. For many smaller format white LED drivers (7-inch screen size or smaller),the PWM signal is converted to a DC control voltage and made to drive the LED current in
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
Серия: TPS61151 (4)
  • Semiconductors > Power Management > LED Driver > Backlight LED Driver
На английском языке: Datasheet Texas Instruments TPS61151DRCT
