Datasheet Texas Instruments INA131BPG4 — Даташит
| Серия | INA131 |
| Модель | INA131BPG4 |
Прецизионный инструментальный усилитель G = 100 8-PDIP
Precision G = 100 Instrumentation Amplifier datasheet
PDF, 121 Кб, Файл опубликован: 27 сен 2000
Купить INA131BPG4 на РадиоЛоцман.Цены — от 442 до 1 010 ₽12 предложений от 12 поставщиков IC INST AMP 1 CIRCUIT 8DIP. Instrumentation Amplifier 1 Circuit 8-PDIP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps | |||
| INA131BPG4 Texas Instruments | 442 ₽ | ||
| INA131BPG4 Texas Instruments | 885 ₽ | ||
| INA131BPG4 Texas Instruments | 908 ₽ | ||
| INA131BPG4 Texas Instruments | 1 010 ₽ | ||
| Pin | 8 |
| Package Type | P |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 50 |
| Carrier | TUBE |
| Маркировка | INA131BP |
| Width (мм) | 6.35 |
| Length (мм) | 9.81 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Bandwidth at Min Gain(Typ) | 0.07 МГц |
| CMRR(Min) | 110 дБ |
| Gain Error (+/-)(Max) | 0.1 % |
| Gain Non-Linearity (+/-)(Max) | 0.002 % |
| Gain(Max) | 100 V/V |
| Gain(Min) | 100 V/V |
| Input Bias Current (+/-)(Max) | 2 нА |
| Input Offset (+/-)(Max) | 50 uV |
| Input Offset Drift (+/-)(Max) | 0.25 uV/C |
| Iq(Typ) | 2.2 мА |
| Noise at 0.1 Hz - 10 Hz(Typ) | 0.4 uVpp |
| Noise at 1kHz(Typ)(nV/rt | 12 Hz |
| Количество каналов | 1 |
| Package Group | PDIP |
| Package Size: mm2:W x L | See datasheet (PDIP) PKG |
| Rating | Catalog |
| Vs(Max) | 36 В |
| Vs(Min) | 4.5 В |
- Programmable-Gain Instrumentation AmplifiersPDF, 47 Кб, Файл опубликован: 27 сен 2000
The INA115 is a precision instrumentation amplifier (IA). Its gain-sense and amplifier output connections are available so that gains can be accurately set using external resistors. By adding switches or a multiplexer, you can make a precision programmable-gain IA (PGIA). Using the circuit topology shown in this bulletin, the switches are in series with op amp inputs so their resistance does not a
Серия: INA131 (4)
- INA131AP INA131APG4 INA131BP INA131BPG4
- Semiconductors > Amplifiers > Instrumentation Amplifiers
