Datasheet Texas Instruments LM20154MHX/NOPB — Даташит
| Серия | LM20154 |
| Модель | LM20154MHX/NOPB |
Синхронный понижающий стабилизатор 4А, 1 МГц с SYNCOUT 16-HTSSOP от -40 до 125
LM20154/LM20154Q 4A, 1MHz Synchronous Buck Regulator with SYNCOUT datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 27 мар 2013
Купить LM20154MHX/NOPB на РадиоЛоцман.Цены — от 27 до 334 ₽14 предложений от 14 поставщиков IC REG BUCK ADJ 4A 16HTSSOP. Buck Switching Regulator IC Positive Adjustable 0.8V 1 Output 4A 16-PowerTSSOP (0.173', 4.40mm Width). PMIC... | |||
| LM20154MHX/NOPB Texas Instruments | 163 ₽ | ||
| LM20154MHX/NOPB Texas Instruments | 172 ₽ | ||
| LM20154MHX/NOPB Texas Instruments | по запросу | ||
| Pin | 16 | 16 |
| Package Type | PWP | PWP |
| Industry STD Term | HTSSOP | HTSSOP |
| JEDEC Code | R-PDSO-G | R-PDSO-G |
| Package QTY | 2500 | 2500 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | 20154 | MH |
| Width (мм) | 4.4 | 4.4 |
| Length (мм) | 5 | 5 |
| Thickness (мм) | 1 | 1 |
| Pitch (мм) | .65 | .65 |
| Max Height (мм) | 1.2 | 1.2 |
| Control Mode | Current Mode |
| Duty Cycle(Max) | 85 % |
| Iout(Max) | 4 A |
| Iq(Typ) | 3.5 мА |
| Package Group | HTSSOP |
| Rating | Catalog |
| Regulated Outputs | 1 |
| Special Features | Enable,Phase Interleaving,Power Good,Synchronous Rectification,Tracking |
| Switching Frequency(Max) | 1000 kHz |
| Switching Frequency(Min) | 1000 kHz |
| Тип | Converter |
| Vin(Max) | 5.5 В |
| Vin(Min) | 2.95 В |
| Vout(Max) | 5 В |
| Vout(Min) | 0.8 В |
- Evaluation Modules & Boards: LM20154EVAL
4A, 1Mhz PowerWiseВ® - Synchronous Buck Regulator with SYNCOUT Evaluation Module
- AN-2077 LM20k POL Module (Rev. A)PDF, 1.3 Мб, Версия: A, Файл опубликован: 3 май 2013
The LM20k is a full-featured synchronous buck switching regulator capable of driving up to 6A of loadcurrent and converting an input voltage between 2.95V and 5.5V down to an output voltage as low as0.8V. Fault protection features include cycle-by-cycle current limit, output power good, and output overvoltageprotection. The dual function soft-start/tracking pin can be used to control the sta - Powering FPGAs Using LM201xx PowerWise Synchronous Buck Regulators (Rev. A)PDF, 45 Кб, Версия: A, Файл опубликован: 3 май 2013
The LM201xx family offers a full range of features and options enabling a FPGA designer to fullycustomize their power solution to meet the system application needs.
Серия: LM20154 (3)
- LM20154MH/NOPB LM20154MHE/NOPB LM20154MHX/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
