Datasheet Texas Instruments TPS77401DGKR — Даташит
СерияTPS774
МодельTPS77401DGKR
LDO-регуляторы 250 мА с Power Good 8-VSSOP от -40 до 125
250-mA LDO Regulators With 8-pin MSOP Packaging datasheet
PDF, 874 Кб, Версия: E, Файл опубликован: 22 мар 2002
Package TypeDGK
Industry STD TermVSSOP
Package QTY2500
МаркировкаAGO
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Accuracy(%)2
Additional FeaturesEnable
Overcurrent Protection
Power Good
Thermal Shutdown
Approx. Price (US$)0.70 | 1ku
Fixed Output Options(V)1.5
1.8
2.8
3.3
5
Iout(Max)(A)0.25
Iq(Typ)(mA)0.09
Noise(uVrms)55
Operating Temperature Range(C)-40 to 125
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)25
Package GroupVSSOP
Package Size: mm2:W x L (PKG)8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
Regulated Outputs(#)1
Vdo(Typ)(mV)200
Vin(Max)(V)10
Vin(Min)(V)2.7
Vout(Max)(V)5.5
Vout(Min)(V)1.5
  • Powering OMAP3 With TPS6235x: Design-In Guide
    PDF, 296 Кб, Файл опубликован: 3 дек 2008
    The OMAP35xx Applications Processors have a diverse set of power management features which potentially enable lower cost power solutions based on your application. This design-in guide describes a power solution based on the TPS6235x device. This guide can be used to evaluate this solution for your design or help you make decisions when designing in this solution.
На английском языке: Datasheet Texas Instruments TPS77401DGKR
