Datasheet Texas Instruments LMP91300NHZT — Даташит
СерияLMP91300
МодельLMP91300NHZT
Индуктивный датчик приближения AFE 24-WQFN от -40 до 125
LMP91300 Industrial Inductive Proximity Sensor AFE datasheet
PDF, 1.7 Мб, Версия: B, Файл опубликован: 27 мар 2014
Pin24
Package TypeNHZ
Industry STD TermWQFN
JEDEC CodeR-PQSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаL91300
Width (мм)4
Length (мм)5
Thickness (мм).8
Pitch (мм).5
Max Height (мм).8
# Input Channels1
Analog Supply (V)40 Min
InterfaceSWIF
Package GroupWQFN
Package Size: mm2:W x L24WQFN: 20 mm2: 4 x 5(WQFN) PKG
Sensor Frequency5k to 5M Hz
  • Measuring Rp of an L-C Sensor for Inductive Sensing
    PDF, 205 Кб, Файл опубликован: 1 окт 2015
    When designing an application using TI’s LDC series of inductive sensors, it is necessary to know the L-C sensor’s equivalent parallel resistance RP at the sensor’s resonant frequency. The RP value changes as the target is moved; the minimum RP occurs when the metal target is closest to the sensor. The maximum RP occurs when the target is at the farthest distance. Accordingly, both values should b
  • Semiconductors > Sensing Products > Inductive Sensing > Inductive Switches
На английском языке: Datasheet Texas Instruments LMP91300NHZT
