Datasheet Texas Instruments DAC712UL/1KG4 — Даташит
СерияDAC712
МодельDAC712UL/1KG4
16-битный цифро-аналоговый преобразователь с 16-битным интерфейсом шины 28-SOIC
16-Bit Digital-to-Analog Converter With 16-Bit Bus Interface datasheet
PDF, 450 Кб, Версия: A, Файл опубликован: 2 июл 2009
Pin28
Package TypeDW
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
Approx. Price (US$)18.28 | 1ku
АрхитектураR-2R
Code to Code Glitch(Typ)(nV-sec)15
DAC: Channels1
Gain Error(Max)(%FSR)0.2
INL(Max)(+/-LSB)2
InterfaceParallel
Internal Reference Drift(Max)(ppm/degC)N/A
Offset Error(Max)(%)N/A
Operating Temperature Range(C)-40 to 85
0 to 70
Output Range Max.(mA)10
Output Range Min.(mA)-10
Тип выходаBuffered Voltage
Power Consumption(Typ)(mW)525
Priority1
Reference: TypeInt
Resolution(Bits)16
Sample / Update Rate(MSPS)0.1
Settling Time(Вµs)10
Special FeaturesOn-chip Offset and Gain Calibration
Zero Code Error(Typ)(mV)N/A
RoHSНе совместим
  • Superposition: The Hidden DAC Linearity Error
    PDF, 106 Кб, Файл опубликован: 2 окт 2000
    A digital-to analog converter (DAC) translates digital signals to analog signals. For example, a 12-bit DAC takes a 12-bit binary number, called an input code, and converts it into one of 4,096 analog output voltages or currents. When the contribution to the output voltage or current of each individual bit is independent of any other, it means that the device exhibits no superposition error or tha
  • Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
На английском языке: Datasheet Texas Instruments DAC712UL/1KG4
