Datasheet Texas Instruments TMS320C6745DPTPT3 — Даташит
СерияTMS320C6745
МодельTMS320C6745DPTPT3
Процессор цифровых сигналов с фиксированной/плавающей запятой 176-HLQFP
TMS320C6745, TMS320C6747 Fixed- and Floating-Point Digital Signal Processor datasheet
PDF, 2.0 Мб, Версия: F, Файл опубликован: 17 июн 2014
Pin176176
Package TypePTPPTP
Industry STD TermHLQFPHLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY4040
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаTMS320C6745DPTPT3
Width (мм)2424
Length (мм)2424
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
DRAMSDRAM
DSP1 C674x
DSP MHz375,456 Max.
DSP Peak MMACS3000
EMAC10/100
I2C2
McASP2
On-Chip L2 Cache256 KB
Operating SystemsDSP/BIOS
Package GroupHLQFP
UART3 SCI
USB1
  • Evaluation Modules & Boards: TMDSOSKL137
    OMAP-L137/TMS320C6747 Floating Point Starter Kit
    XDS200 USB Debug Probe
  • TMS320C6745 Technical Brief (Rev. B)
    PDF, 85 Кб, Версия: B, Файл опубликован: 18 фев 2009
    The C674x Floating-point Processor generation combines a new level of performance / precision and dynamic range with high power efficiency and system integration. The C674x processors are completely code compatible with other C67x processors.
  • TMS320C6747/45/43 Complementary Products
    PDF, 27 Кб, Файл опубликован: 23 сен 2009
    This article has been contributed to the TI DaVinciв„ў and OMAPв„ў Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/C6747/45/43_Complementary_Products .This Wiki article serves as a repository of complimentary dev
  • Using the TMS320C6747/45/43 Bootloader (Rev. C)
    PDF, 2.6 Мб, Версия: C, Файл опубликован: 1 июн 2012
    This application report describes various boot mechanisms supported by the C6747/45/43 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, default s
  • TMS320C6747/45/43 Power Consumption Summary
    PDF, 19 Кб, Файл опубликован: 30 июн 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/C6747/45/43_Power_Consumption_Summary.This article discusses the power consumption of the Texas Instruments TMS320C6747
  • Using the OMAP-L1x7 Bootloader (Rev. G)
    PDF, 2.6 Мб, Версия: G, Файл опубликован: 1 июн 2012
    This application report describes various boot mechanisms supported by the OMAP-L1x7 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, default set
  • TMS320C6747/45/43 & OMAP-L1x7 USB Downstream Host Compliance Testing
    PDF, 2.8 Мб, Файл опубликован: 12 мар 2009
    This appication report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • TMS320C6747/45/43 & OMAP-L1x7 USB Upstream Device Compliance Testing
    PDF, 510 Кб, Файл опубликован: 12 мар 2009
    This application report describes the TMS320C674x/OMAP-L1x electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The on-the-go (OTG) controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS), and low-speed (LS).
  • OMAP-L137 TMS320C6747/6745/6743 Pin Multiplexing Utility (Rev. A)
    PDF, 39 Кб, Версия: A, Файл опубликован: 26 сен 2009
    The OMAP-L137, C6747/6745/6743 devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. This software allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices support the peripherals that are selected. This software is useful to anyo
  • Power Solution using a Dual DCDC Converter and a LDO (Rev. A)
    PDF, 174 Кб, Версия: A, Файл опубликован: 25 мар 2010
  • Power Solution Using Discrete DC/DC Converters and LDOs (Rev. B)
    PDF, 299 Кб, Версия: B, Файл опубликован: 26 авг 2010
  • Power Solution using LDO's (Rev. A)
    PDF, 125 Кб, Версия: A, Файл опубликован: 25 мар 2010
  • TMS320C674x/OMAP-L1x USB Compliance Checklist
    PDF, 89 Кб, Файл опубликован: 12 мар 2009
    This application report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • OMAP-L1x/C674x/AM1x SOC Architecture and Throughput Overview
    PDF, 19 Кб, Файл опубликован: 12 фев 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L1x/C674x/AM1x_SOC_Architecture_and_Throughput_Overview. This collection of Wiki articles provide i
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > Media Processors > Audio Processors
На английском языке: Datasheet Texas Instruments TMS320C6745DPTPT3
