Datasheet Texas Instruments LM317LITPX/NOPB — Даташит
СерияLM317L-N
МодельLM317LITPX/NOPB
Регулируемый линейный регулятор с входом 100 мА, 40 В, 6-DSBGA, от -40 до 125
LM317L-N Wide VIN 100-mA Adjustable Voltage Regulator datasheet
PDF, 1.9 Мб, Версия: L, Файл опубликован: 19 янв 2018
Pin66
Package TypeYPBYPB
Industry STD TermDSBGADSBGA
JEDEC CodeR-XBGA-NR-XBGA-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаP1
Thickness (мм)0.370.37
Pitch (мм)0.50.5
Max Height (мм)0.5750.575
Точность3 %
Основные особенностиN/A
Iout(Max)0.1 A
Iq(Typ)0.05 мА
Noise38 uVrms
Output Capacitor TypeN/A
Output OptionsAdjustable Output
PSRR @ 100KHz63 дБ
Package GroupDSBGA
Regulated Outputs1
Thermal Resistance ОёJA160 В°C/W
Vdo(Typ)1800 мВ
Vin(Max)40 В
Vin(Min)4.2 В
Vout(Max)38 В
Vout(Min)1.2 В
  • AN-181 3-Terminal Regulator is Adjustable (Rev. B)
    PDF, 314 Кб, Версия: B, Файл опубликован: 5 май 2013
    Until now all of the 3-terminal power IC voltage regulators have a fixed output voltage. In spite of this limitation their ease of use low cost and full on-chip overload protection have generated wide acceptance. Now with the introduction of the LM117 it is possible to use a single regulator for any output voltage from 1.2 V to 37 V at 1.5A. Selecting close-tolerance outp
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • TO-92 Packing Options / Ordering Instructions (Rev. A)
    PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
  • Linear power for automated industrial systems
    PDF, 1.8 Мб, Файл опубликован: 9 янв 2015
    Designing a robust power management system for industrial automated equipment requires thorough understanding of the surroundings and conditions that affect the functionality. During the past few decades industrial and factory automation systems have become more robust intelligent and connected which has drastically increased the footprint for semiconductor components. This change has created a
  • AN-182 Improving Power Supply Reliability with IC Power Regulators (Rev. B)
    PDF, 82 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report discusses improving power supply reliability with IC power regulators.
  • Semiconductors > Analog and Mixed-Signal > Power Management > Linear Regulator (LDO) > Single Channel LDO
На английском языке: Datasheet Texas Instruments LM317LITPX/NOPB
