Datasheet Texas Instruments TL494CPWG4 — Даташит
| Серия | TL494 |
| Модель | TL494CPWG4 |
Цепь управления ШИМ 16-TSSOP от 0 до 70
TL494 Pulse-Width-Modulation Control Circuits datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 27 фев 2017
Купить TL494CPWG4 на РадиоЛоцман.Цены — от 17 до 102 ₽13 предложений от 13 поставщиков IC REG CTRLR MULT TOP 16TSSOP. Buck, Boost, Flyback, Forward Converter, Full-Bridge, Half-Bridge, Push-Pull Regulator Positive Output Step-Up, Step-Down, Step-Up/Step-Down DC-DC... | |||
| TL494CPWG4 Rochester Electronics | 21 ₽ | ||
| TL494CPWG4 Texas Instruments | 43 ₽ | ||
| TL494CPWG4 Texas Instruments | 102 ₽ | ||
| TL494CPWG4 Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 90 |
| Carrier | TUBE |
| Маркировка | T494 |
| Width (мм) | 4.4 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Control Method | Voltage |
| Duty Cycle(Max) | 45 % |
| Frequency(Max) | 300 kHz |
| Frequency(Min) | 1 kHz |
| Gate Drive(Typ) | 0.2 A |
| Рабочий диапазон температур | от -40 до 85,0 до 70 C |
| Package Group | TSSOP |
| Rating | Catalog |
| Special Features | Adjustable Switching Frequency,Error Amplifier,Multi-topology |
| Topology | Boost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
| UVLO Thresholds On/Off | N/A В |
| Vin(Max) | 38 В |
| Vin(Min) | -0.3 В |
- Isolated Multiple Output Flyback Converter Design Using TL494PDF, 741 Кб, Файл опубликован: 18 июн 2014
- Off-Line SMPS Failure Modes PWM Switchers and DC-DC ConvertersPDF, 71 Кб, Файл опубликован: 22 мар 2000
Today's voltage regulator modules (VRMs) employ off-line SMPS techniques. Traditionally, they are usually discarded when they fail because they are so challenging to debug and so inexpensive to replace. Investigation of these failed modules reveals some common failure modes. Some failures are caused by other systems' passive components that fail after repeated electrical stress. Recognizing these - Designing Switching Voltage Regulators With the TL494 (Rev. E)PDF, 329 Кб, Версия: E, Файл опубликован: 26 июл 2005
Designing Switching Voltage Regulators With the TL494 - Understanding Buck Power Stages In Switchmode Power SuppliesPDF, 173 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous - Understanding Boost Power Stages In Switchmode Power SuppliesPDF, 149 Кб, Файл опубликован: 4 мар 1999
A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o - Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TL494 (25)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
