Datasheet Texas Instruments LM135H — Даташит
СерияLM135
МодельLM135H
Датчик температуры с аналоговым выходом, военный класс, герметичный TO 3-TO от -55 до 150
LMx35, LMx35A Precision Temperature Sensors datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 10 фев 2015
Pin33
Package TypeNDVNDV
Industry STD TermTO-CANTO-CAN
JEDEC CodeO-MSFM-PO-MSFM-P
Package QTY500500
МаркировкаLM135HLM135H
Width (мм)4.6994.699
Length (мм)4.6994.699
Thickness (мм)2.3622.362
Max Height (мм)2.6672.667
InterfaceAnalog Output
Local Sensor Accuracy(Max)3 +/- C
Рабочий диапазон температурот -55 до 150 C
Package GroupTO
Package Size: mm2:W x L3TO: 22 mm2: 4.699 x 4.699(TO) PKG
Supply Current(Max)400 uA
Supply Voltage(Min)5 В
RoHSSee ti.com
  • An Acoustic Transformer Powered Super-High Isolation Amplifier
    PDF, 212 Кб, Файл опубликован: 4 окт 2004
  • AN-293 Control Applications of CMOS DACs
    PDF, 424 Кб, Файл опубликован: 10 май 2004
    Application Note 293 Control Applications of CMOS DACs
  • Applications of the LM3524 Pulse Width Modulator (Rev. B)
    PDF, 549 Кб, Версия: B, Файл опубликован: 23 апр 2013
    The LM3524 regulating pulse-width-modulator (PWM) is commonly used as the control element inswitching regulator power supplies. This is in keeping with its intended purpose. Engineers closelyassociate this part with switching power supplies. Nevertheless, the flexible combination of elements (seebox) within the LM3524 also allows it to be used in a number of other applications outside the po
  • IC Temp Sensor Provides Thermocouple Cold-Junction Compensation (Rev. B)
    PDF, 271 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Two circuits using the LM335 for thermocouple cold-junction compensation have been described. With asingle room temperature calibration, these circuits are accurate to В±3/4В°C over a 0В°C to 70В°C temperaturerange using J or K type thermocouples. In addition, a thermocouple amplifier using an LM335 for coldjunctioncompensation has been described for which worst case error can be as low as 1В°C p
  • AN-460 LM34/LM35 Precision Monolithic Temperature Sensors (Rev. C)
    PDF, 495 Кб, Версия: C, Файл опубликован: 1 май 2013
    This application report discusses the details and uses of the Texas Instruments LM34 and LM35 asprecision temperature sensors.
  • AN-262 Applying Dual and Quad FET Op Amps (Rev. B)
    PDF, 1.1 Мб, Версия: B, Файл опубликован: 6 май 2013
    The availability of dual and quad packaged FET op amps offers the designer all the traditional capabilitiesof FET op amps including low bias current and speed and some additional advantages. The cost-peramplifieris lower because of reduced package costs. This means that more amplifiers are available toimplement a function at a given cost making design easier. At the same time the availab
  • AN-298 Isolation Techniques for Signal Conditioning (Rev. B)
    PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note provides information and examples of isolation techniques for signal conditioning.
Серия: LM135 (2)
  • Semiconductors > Space & High Reliability > Sensors > Temperature Sensor
На английском языке: Datasheet Texas Instruments LM135H
