Линейка продуктов KEEN SIDE
Datasheet Texas Instruments 74AC11286DR — Даташит
Серия74AC11286
Модель74AC11286DR
9-битные генераторы/контролеры четности с драйвером шины Порт ввода-вывода четности 14-SOIC -40–85
Datasheet
TSP
Pin14
Package TypeD
Width (мм)3.91
Length (мм)8.65
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: 74AC11286 (3)
  • Semiconductors > Logic > Specialty Logic > Counter/Arithmetic/Parity Function
На английском языке: Datasheet Texas Instruments 74AC11286DR
