Datasheet Texas Instruments LM6142AIMX/NOPB — Даташит
СерияLM6142
МодельLM6142AIMX/NOPB
Двойной высокоскоростной/маломощный операционный усилитель ввода/вывода с частотой 17 МГц, Rail-to-Rail, 8-SOIC, от -40 до 85
LM6142/LM6144 17В MHz Rail-to-Rail Input-Output Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 13 мар 2013
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка2AIMLM614
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураBipolar
CMRR(Min)84 дБ
CMRR(Typ)107 дБ
GBW(Typ)17 МГц
Input Bias Current(Max)280000 pA
Iq per channel(Max)0.8 мА
Iq per channel(Typ)0.65 мА
Количество каналов2
Offset Drift(Typ)3 uV/C
Output Current(Typ)8 мА
Rail-to-RailIn,Out
Slew Rate(Typ)25 V/us
Total Supply Voltage(Max)24 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.8 +5V=5, +/-5V=10
Vn at 1kHz(Typ)16 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)1 мВ
  • Effect of Heavy Loads on Accuracy and Linearity of Op Amp Circuits (Rev. B)
    PDF, 81.7 Мб, Версия: B, Файл опубликован: 22 апр 2013
    This application report discusses the effect of heavy loads on the accuracy and linearity of operationalamplifier circuits.
  • AN-1515 A Comprehensive Study of the Howland Current Pump (Rev. A)
    PDF, 165 Кб, Версия: A, Файл опубликован: 26 апр 2013
    It is well known to analog experts that you can use the positive and negative inputs of an operationalamplifier to make a high-impedance current source (current pump) using a conventional operationalamplifier (op amp). This basic circuit can put out both + and - output current (or zero current) into variousloads. The theory is simple. But the practical problems involved are not so simple or
На английском языке: Datasheet Texas Instruments LM6142AIMX/NOPB
