Datasheet Texas Instruments LMR14050SQDPRRQ1 — Даташит
Серия | LMR14050-Q1 |
Модель | LMR14050SQDPRRQ1 |
Автомобильная промышленность, 40 В, 5 А SIMPLE SWITCHER®, понижающий стабилизатор 2,2 МГц с током 40 мкА IQ 10-WSON от -40 до 125
LMR14050-Q1 SIMPLE SWITCHERВ® 40 V, 5 A Step-Down Converter with 40 µA IQ datasheet
PDF, 1.5 Мб, Версия: A, Файл опубликован: 3 фев 2016
Pin | 10 | 10 |
Package Type | DPR | DPR |
Industry STD Term | WSON | WSON |
JEDEC Code | S-PDSO-N | S-PDSO-N |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | LMR | 1405SQ |
Width (мм) | 4 | 4 |
Length (мм) | 4 | 4 |
Thickness (мм) | .75 | .75 |
Pitch (мм) | .8 | .8 |
Max Height (мм) | .8 | .8 |
Control Mode | Current Mode |
Duty Cycle(Max) | 98 % |
Iout(Max) | 5 A |
Iq(Typ) | 0.04 мА |
Package Group | WSON |
Rating | Automotive |
Regulated Outputs | 1 |
Special Features | Enable,Frequency Synchronization,Light Load Efficiency,Power Good,Pre-Bias Start-Up,Spread Spectrum,Tracking,UVLO Adjustable |
Switching Frequency(Max) | 2500 kHz |
Switching Frequency(Min) | 200 kHz |
Тип | Converter |
Vin(Max) | 40 В |
Vin(Min) | 4 В |
Vout(Max) | 30 В |
Vout(Min) | 1 В |
- Evaluation Modules & Boards: LMR14050QDPREVM
LMR14050QDPR Wide Vin Step-Down Converter Evaluation Module
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: LMR14050SEVM
LMR14050S Step-Down Converter Evaluation Module
- How to Evaluate the Maximum Inductor in Internal Compensation PCM Buck ConverterPDF, 2.3 Мб, Файл опубликован: 20 сен 2017
With simple frequency compensation, Peak Current Mode (PCM) control is commonly used in integratedcircuits (IC) to improve the line and load transient performance. Slope compensation is implemented toprevent sub-harmonic oscillations at a duty cycle greater than 50%. Usually the inductor is considered asa current source in a simplified PCM buck converter model, which actually has a significa
Серия: LMR14050-Q1 (7)
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
