Datasheet Texas Instruments LM3153MH-3.3/NOPB — Даташит
Серия | LM3153 |
Модель | LM3153MH-3.3/NOPB |
КОНТРОЛЛЕР SIMPLE SWITCHER®, синхронное понижающее напряжение 42 В, 14-HTSSOP от -40 до 125
LM3151/52/53 SIMPLE SWITCHER CONTROLLER, High Input Voltage Sync Step-Down datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 4 мар 2011
Pin | 14 | 14 |
Package Type | PWP | PWP |
Industry STD Term | HTSSOP | HTSSOP |
Package QTY | 94 | 94 |
Carrier | TUBE | TUBE |
Маркировка | LM3153 | -3.3 |
Width (мм) | 4.4 | 4.4 |
Length (мм) | 5 | 5 |
Thickness (мм) | 1 | 1 |
Pitch (мм) | .65 | .65 |
Max Height (мм) | 1.2 | 1.2 |
Control Mode | COT with emulated ripple |
Duty Cycle(Max) | 72 % |
Iout(Max) | 12 A |
Iq(Typ) | 3.6 мА |
Number of Phases | 1 |
Package Group | HTSSOP |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable,Synchronous Rectification,Tracking |
Switching Frequency(Max) | 750 kHz |
Switching Frequency(Min) | 750 kHz |
Тип | Controller |
Vin(Max) | 18 В |
Vin(Min) | 8 В |
Vout(Max) | 3.3 В |
Vout(Min) | 3.3 В |
- AN-1229 SIMPLE SWITCHER PCB Layout Guidelines (Rev. C)PDF, 374 Кб, Версия: C, Файл опубликован: 23 апр 2013
This application report provides SIMPLE SWITCHER™ PCB layout guidelines. - Controlling Output Ripple & Achiev ESR Indep Constant On-Time Reg Designs (Rev. A)PDF, 178 Кб, Версия: A, Файл опубликован: 23 апр 2013
Of all the voltage regulator control strategies ever devised, the hysteretic regulator is probably about thesimplest. This control methodology simply turns a switch on when the output voltage is below a referenceand turns the switch off when the output rises to a slightly higher reference. The output ripple is thereforea direct function of the difference between the upper and lower reference
Серия: LM3153 (3)
- LM3153MH-3.3/NOPB LM3153MHE-3.3/NOPB LM3153MHX-3.3/NOPB
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
LM3153MH3.3/NOPB, LM3153MH 3.3/NOPB
