Datasheet Texas Instruments UCC28084PWR — Даташит
СерияUCC28084
МодельUCC28084PWR
Режим тока Двухтактный ШИМ с программируемой компенсацией наклона 8-TSSOP от -40 до 85
8-Pin Current Mode Push-Pull PWM ControllersWith Programmable Slope Compensation datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 12 май 2009
Package TypePW
Industry STD TermTSSOP
Package QTY2000
Маркировка28084
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Control MethodCurrent
Duty Cycle(Max)50 %
Frequency(Max)1000 kHz
Frequency(Min)50 kHz
Gate Drive(Typ)1 A
Package GroupTSSOP
Special FeaturesMulti-topology,Programmable Slope Compensation,Soft Start
TopologyHalf-Bridge,Push-Pull
UVLO Thresholds On/Off4.3/4.1 В
Vin(Max)15 В
Vin(Min)4.1 В
  • How to Specify the Current Sense Resistor in a Converter using the UCC28083 (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 21 июл 2011
    How to Specify the Current Sense Resistor in a Converter Using the UCC28083
  • A New Synchronization Circuit for Power Converters (Rev. A)
    PDF, 209 Кб, Версия: A, Файл опубликован: 21 апр 2010
    The synchronization of multiple PWM and PFC controllers is desirable for many reasons. The most common reason is that it keeps all the noise at one particular frequency and makes it easier to filter. The circuit described changes the slope of the ramp to lock the converter’s switching frequency to an applied signal by a phase locked loop turning it into a voltage controlled oscillator. Furthermore
  • Current Doubler Rectifier Offers Ripple Current Cancellation
    PDF, 116 Кб, Файл опубликован: 21 сен 2004
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments UCC28084PWR
