Datasheet Texas Instruments 5962-9203103QEA — Даташит
СерияUC1863
Модель5962-9203103QEA
Резонансные контроллеры блоков питания 16-CDIP от -55 до 125
Resonant-Mode Power Supply Controllers datasheet
PDF, 3.9 Мб, Версия: B, Файл опубликован: 13 сен 2007
Микросхема Контроллер PWM, Voltage Mode PWM Controller 500mA 550kHz 16Pin CDIP Tube
5962-9203103QEA
3 245 ₽
5962-9203103QEA
4 470 ₽
5962-9203103QEA
Pin16
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
Width (мм)6.92
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Control MethodVoltage
Duty Cycle(Max)50 %
Основные особенностиError Amplifier,Soft Start,Soft Switching,Multi-topology
Frequency(Max)500 kHz
Frequency(Min)50 kHz
Package GroupCDIP
RatingMilitary
TopologyFull-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/Off8/7 В
Vin(Max)22 В
Vin(Min)7 В
RoHSSee ti.com
  • U-138 Zero Voltage Switching Resonant Power Conversion
    PDF, 794 Кб, Файл опубликован: 5 сен 1999
    This application note explores the technique of zero voltage switching in modern power conversion. It describes several ZVS topologies and applications limitations of the ZVS technique and a generalized design procedure. Two design examples are presented: a 50W DC/DC converter and an off-line 300W multiple output power supply. This discussion concludes with a performance comparison of ZVS conve
  • U-122 A New Family of Integrated Circuits Controls Resonant Mode Power
    PDF, 272 Кб, Файл опубликован: 5 сен 1999
    This application note introduces the UC3861-8 family of ICs which are optimized for the control of zero-current-switched and zero-voltage-switched quasi-resonant converters. Differences among members of this device family result from the various combinations of UVLO thresholds and output options. The one-shot pulse steering logic is configured to program either on time for ZCS systems (UC1865-186
Серия: UC1863 (6)
  • Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
59629203103QEA, 5962 9203103QEA
На английском языке: Datasheet Texas Instruments 5962-9203103QEA
