Datasheet Texas Instruments SNJ54AS808BFK — Даташит
СерияSN54AS808B
МодельSNJ54AS808BFK
Шестнадцатеричный 2 входа и драйверы 20-LCCC от -55 до 125
Hex 2-Input And Drivers datasheet
PDF, 608 Кб, Версия: C, Файл опубликован: 1 янв 1995
Микросхема Логический чип, AND Gate 6Element 2IN Bipolar 20Pin CLLCC Tube
SNJ54AS808BFK
2 050 ₽
SNJ54AS808BFK
2 556 ₽
SNJ54AS808BFK
SNJ54AS808BFK
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
МаркировкаSNJ54AS5962-88522012A808BFK
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
Bits6
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)0.013 мА
Тип входаTTL
Output Drive (IOL/IOH)(Max)-2/20 мА
Тип выходаTTL
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
tpd @ Nom Voltage(Max)6.5 нс
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
На английском языке: Datasheet Texas Instruments SNJ54AS808BFK
