Datasheet Texas Instruments THS5641AIPWG4 — Даташит
СерияTHS5641A
МодельTHS5641AIPWG4
8-разрядный ЦАП CommsDAC(TM), 100 MSPS, масштабируемые токовые выходы от 2 мА до 20 мА 28-TSSOP от -40 до 85
8-Bit, 100 MSPS, CommsDAC(TM) Digital-to-Analog Converter (Rev. A)
PDF, 915 Кб, Версия: A, Файл опубликован: 25 сен 2002
Pin28
Package TypePW
Industry STD TermTSSOP
Package QTY50
МаркировкаTJ5641A
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)3.19 | 1ku
АрхитектураCurrent Source
DAC: Channels1
InterfaceParallel CMOS
Operating Temperature Range(C)-40 to 85
Package GroupTSSOP
Package Size(mm2=WxL)28TSSOP: 62 mm2: 6.4 x 9.7
Power Consumption(Typ)(mW)100
Resolution(Bits)8
SFDR(dB)67
SNR(dB)50
Sample / Update Rate(MSPS)100
Settling Time(?s)0.035
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op amp differential to single-end
    As system bandwidths have increased, an accurate estimate of the noise contribution for each element in the signal channel has become increasingly important. Many designers are not, however, particula
  • Semiconductors > Data Converters > Digital to Analog Converter > High Speed DAC (>10MSPS)
На английском языке: Datasheet Texas Instruments THS5641AIPWG4
