Оптопары и оптореле Megawin
Datasheet Texas Instruments SN74AHCT14DGVR — Даташит
СерияSN74AHCT14
МодельSN74AHCT14DGVR
Инверторы с шестигранным триггером Шмитта 14-TVSOP от -40 до 85
SNx4AHCT14 Hex Schmitt-Trigger Inverters datasheet
PDF, 2.1 Мб, Версия: Q, Файл опубликован: 30 июн 2014
Pin14
Package TypeDGV
Industry STD TermTVSOP
Package QTY2000
МаркировкаHB14
Width (мм)4.4
Length (мм)3.6
Thickness (мм)1.05
Pitch (мм).4
Max Height (мм)1.2
Bits6
F @ Nom Voltage(Max)70 Mhz
ICC @ Nom Voltage(Max)0.02 мА
Output Drive (IOL/IOH)(Max)-8/8 мА
Package GroupTVSOP
Package Size: mm2:W x L14TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) PKG
Schmitt TriggerYes
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)12 нс
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AHCT14DGVR
