Datasheet ТI ADS8319IBDGST — Даташит
| Серия | ADS8319 |
| Модель | ADS8319IBDGST |
Прецизионный 16-битный SAR с интерфейсом SPI в MSOP-10 10-VSSOP от -40 до 85
ADS8319 16-Bit, 500-kSPS, Serial Interface, Micropower, Miniature, SAR Analog-to-Digital Converter datasheet
PDF, 2.3 Мб, Версия: C, Файл опубликован: 9 дек 2016
- The IBIS model, Part 2: Determining the total quality of an IBIS modelPDF, 221 Кб, Файл опубликован: 14 мар 2011
- Low Power Input and Reference Driver Circuit for ADS8318 and ADS8319PDF, 1.5 Мб, Файл опубликован: 24 июн 2009
The one size fits all approach to operational amplifiers is not effective. Every application has its own specific requirements that must be fulfilled. Appropriate selection of the op amp that drives an analog-to-digital converter (ADC) in a low-power application is a critical step. Most available low-power op amps trade off low-power features with other parameters such as bandwidth, settling t - Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different - Determining Minimum Acquisition Times for SAR ADCs, part 2PDF, 215 Кб, Файл опубликован: 17 мар 2011
The input structure circuit of a successive-approximation register analog-to-digital converter (SAR ADC) incombination with the driving circuit forms a transfer function that can be used to determine minimum acquisition times for different types of applied input signals. This application report, which builds on Determining Minimum Acquisition Times for SAR ADCs When a Step Function is Applied to - Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS8319 (7)
- ADS8319IBDGSR ADS8319IBDGST ADS8319IBDRCR ADS8319IBDRCT ADS8319IDGSR ADS8319IDGST ADS8319IDRCT
