Datasheet Texas Instruments DAC5672IPFBRG4 — Даташит
СерияDAC5672
МодельDAC5672IPFBRG4
14 бит, 275 MSPS, двойной цифро-аналоговый преобразователь 48-TQFP от -40 до 85
Dual 14 Bit 275 MSPS DAC (Rev. C)
PDF, 1.3 Мб, Версия: C, Файл опубликован: 29 ноя 2010
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаDAC5672I
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Approx. Price (US$)13.40 | 1ku
АрхитектураCurrent Source
DAC: Channels2
IMD3(dBc)79
InterfaceParallel CMOS
Operating Temperature Range(C)-40 to 85
Package GroupTQFP
Package Size(mm2=WxL)48TQFP: 81 mm2: 9 x 9
Power Consumption(Typ)(mW)330
Resolution(Bits)14
SFDR(dB)84
SNR(dB)77
Sample / Update Rate(MSPS)275
Settling Time(?s)0.02
  • Evaluation Modules & Boards: DAC5672EVM
    DAC5672 Evaluation Module
  • Evaluation Modules & Boards: DAC5652EVM
    DAC5652 evaluation module
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • Passive Terminations for Current Output DACs
    PDF, 244 Кб, Файл опубликован: 10 ноя 2008
    The correct implementation of the high-speed DAC output termination is critical to achieving the best possible performance. The typical application involves choosing the correct network to create the
  • High Speed, Digital-to-Analog Converters Basics (Rev. A)
    PDF, 829 Кб, Версия: A, Файл опубликован: 23 окт 2012
    High Speed DAC (>10MSPS) High Speed, Digital-to-Analog Converters Basics
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op amp differential to single-end
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the refe
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed, high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483, which is capable of
  • Superposition: The Hidden DAC Linearity Error
    PDF, 106 Кб, Файл опубликован: 2 окт 2000
    A digital-to analog converter (DAC) translates digital signals to analog signals. For example, a 12-bit DAC takes a 12-bit binary number, called an input code, and converts it into one of 4,096 analog
Серия: DAC5672 (3)
  • Semiconductors > Data Converters > Digital to Analog Converter > High Speed DAC (>10MSPS)
На английском языке: Datasheet Texas Instruments DAC5672IPFBRG4
