Datasheet Texas Instruments SN65HVD08PE4 — Даташит
СерияSN65HVD08
МодельSN65HVD08PE4
Приемопередатчик RS-485 3,3/5 В 8-PDIP от -40 до 85
SNx5HVD08 Wide Supply Range RS-485 Transceiver datasheet
PDF, 988 Кб, Версия: D, Файл опубликован: 9 июл 2015
Чип интерфейса, 3.3/5V RS-485 Transceiver 8-PDIP -40℃ to 85℃y
SN65HVD08PE4
65 ₽
SN65HVD08PE4
191 ₽
SN65HVD08PE4
SN65HVD08PE4
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
Маркировка65HVD08
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Common Mode Range-7 to 12
DuplexHalf
Fail SafeIdle,Open,Short
Fault Protection-9 to 14 В
HBM ESD16 kV
ICC(Max)16 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes256
Package GroupPDIP
Signaling Rate(Max)10 Mbps
Supply Voltage(s)(Nom)3.3, 5 В
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • RS-485 for Digital Motor Control Applications
    PDF, 180 Кб, Файл опубликован: 12 май 2003
    This application report focuses on the benefits of using RS-485 signaling for motor control and motion control applications. This technology has several benefits for these applications in terms of noise immunity, wide common-mode voltage range, adequate data rate, and multipoint capability. Other applications also use RS-485 signaling to take advantage of these same benefits. Applications such as
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65HVD08PE4
