Datasheet Texas Instruments TPS75718KTT — Даташит
СерияTPS757
МодельTPS75718KTT
Стабилизаторы напряжения с малым падением напряжения, 3 А, с быстрым переходным процессом 5-DDPAK/TO-263 от -40 до 125
Fast-Transient Response 3-A Low Dropout Voltage Regulators datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 5 фев 2009
Pin5
Package TypeKTT
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
Width (мм)8.42
Length (мм)10.16
Thickness (мм)4.58
Pitch (мм)1.7
Max Height (мм)4.83
Рекомендуемая замена
ReplacementTPS75718KTTT
Replacement CodeS
Accuracy(%)3
Additional FeaturesEnable
Overcurrent Protection
Power Good
Thermal Shutdown
Approx. Price (US$)2.90 | 1ku
Fixed Output Options(V)1.5
1.8
2.5
3.3
Iout(Max)(A)3
Iq(Typ)(mA)0.12
Noise(uVrms)35
Operating Temperature Range(C)-40 to 125
Output OptionsAdjustable Output
Fixed Output
Package GroupDDPAK/TO-263
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
Regulated Outputs(#)1
Vdo(Typ)(mV)150
Vin(Max)(V)5.5
Vin(Min)(V)2.8
Vout(Max)(V)5
Vout(Min)(V)1.22
RoHSНе совместим
  • TI Power Solutions Power Up Altera FPGAs
    PDF, 167 Кб, Файл опубликован: 18 окт 2002
    Power requirements and power consumptions for Altera FPGAs including ACEX 1K APEX II Mercury and Stratix families are summarized and calculated at typical applications as a first?cut estimation for engineers designing with those multivoltage families. Design examples which cover LDOs SWIFT DC/DC controllers and power modules are demonstrated. Certain sequencing strategy is shown in each des
На английском языке: Datasheet Texas Instruments TPS75718KTT
