Datasheet Texas Instruments ADS7841EB — Даташит
СерияADS7841
МодельADS7841EB
12-разрядный 4-канальный аналого-цифровой преобразователь с дискретизацией последовательного вывода 16-SSOP
ADS7841: 12-Bit, 4-Channel Serial Output Sampling Analog-to-Digital Converter datasheet
PDF, 490 Кб, Версия: B, Файл опубликован: 19 июл 2001
Pin161616
Package TypeDBQDBQDBQ
Industry STD TermSSOPSSOPSSOP
Package QTY757575
CarrierTUBETUBETUBE
Маркировка7841EADSB
Width (мм)3.93.93.9
Length (мм)4.94.94.9
Thickness (мм)1.51.51.5
Pitch (мм).64.64.64
Max Height (мм)1.751.751.75
# Input Channels4
Analog Voltage AVDD(Max)5.25 В
Analog Voltage AVDD(Min)2.7 В
АрхитектураSAR
Digital Supply(Max)5.25 В
Digital Supply(Min)2.7 В
INL(Max)1 +/-LSB
Input Range(Max)5.25 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceSerial
Package GroupSSOP
Package Size: mm2:W x L16SSOP: 19 mm2: 3.9 x 4.9(SSOP) PKG
Power Consumption(Typ)1.8 mW
Reference ModeExt
Разрешение12 Bits
SINADN/A дБ
SNR72 дБ
Sample Rate (max)200kSPS SPS
Sample Rate(Max)0.2 MSPS
THD(Typ)-78 дБ
  • Using the ADS7841 and ADS7844 with 15-Clock Cycles
    PDF, 188 Кб, Файл опубликован: 30 июн 2005
    This application report presents an analysis on the use of the 15-clock cycle method of operation for the ADS7841 and ADS7844 described in their respective data sheets. The advent of commercially available processors such as the TMS470 no longer restricts users from implementing the 15-clock method with simple microprocessors. This method, however, does present some challenges to the software inte
  • Apply TI TSC for Various and Multiple Functions
    PDF, 316 Кб, Файл опубликован: 11 дек 2006
    This application report presents several examples showing how a touch screen controller (TSC) from Texas Instruments provides a variety of functions such as graphs, scroll bars, pressure buttons, and analog dials. A simple resistive TSC can be used to achieve all of these functions as long as they are not activated simultaneously. This application report demonstrates a few simple examples how th
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS7841EB
