Datasheet Texas Instruments TLV431CLPM — Даташит
СерияTLV431
МодельTLV431CLPM
Низковольтный регулируемый прецизионный шунтирующий регулятор 3-TO-92 от 0 до 70
Datasheet TLV431, TLV431A, TLV431B
PDF, 2.2 Мб, Версия: X, Файл опубликован: 1 май 2018, Страниц: 55
TLV431x Low-Voltage Adjustable Precision Shunt Regulator
Pin3
Package TypeLP
Industry STD TermTO-92
JEDEC CodeO-PBCY-W
Package QTY2000
CarrierAMMO
МаркировкаV431C
Width (мм)4.3
Length (мм)4.3
Thickness (мм)3.6
Max Height (мм)5.34
Approx. Price (US$)0.15 | 1ku
Initial Accuracy(Max)(%)1.5
Iout/Iz(Max)(mA)15
Min Iz for Regulation(uA)55
Operating Temperature Range(C)-40 to 125
-40 to 85
0 to 70
Package GroupTO-92
Package Size: mm2:W x L (PKG)3TO-92: 19 mm2: 3.68 x 5.2(TO-92)
Pin/Package3SOT-23
3SOT-89
3TO-92
5SOT-23
Reference VoltageAdjustable
Temp Coeff(Max)(ppm/ degree C)138
Temp Coeff(Typ)(ppm/ degree C)46
VO Adj(Max)(V)6
VO Adj(Min)(V)1.24
VO(V)N/A
  • Implementing a Buck Converter With the TPS23753A
    PDF, 454 Кб, Файл опубликован: 20 сен 2010
    The TPS23753A is intended for isolated applications and does not incorporate an internal voltage-regulation error amplifier. Due to its integration and features it may be advantageous to use the TPS23753A in non-isolated applications. This application report shows additional circuits necessary to implement a low-side switch buck converter using the TPS23753A.
  • Supplying TPS61200 With a Single Solar Cell (Rev. B)
    PDF, 129 Кб, Версия: B, Файл опубликован: 6 сен 2011
    This application report explains how to use the TPS61200 in combination with a single solar cell to charge a battery or storage device. A characteristic of solar cells is the internal resistance that can vary from less than 10 Ω up to more than 100 Ω. Therefore it is important to control the load placed on the solar cell to ensure a reliable start-up of the application. This report describes an a
  • Setting the shunt voltage on an adjustable shunt regulator
    PDF, 170 Кб, Файл опубликован: 1 сен 2011
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
На английском языке: Datasheet Texas Instruments TLV431CLPM
