Datasheet Texas Instruments TLV431CDBVRE4 — Даташит
СерияTLV431
МодельTLV431CDBVRE4
Низковольтный регулируемый прецизионный шунтовый регулятор с точностью 1,5 % 5-SOT-23 от 0 до 70
Datasheet TLV431, TLV431A, TLV431B
PDF, 2.2 Мб, Версия: X, Файл опубликован: 1 май 2018, Страниц: 55
TLV431x Low-Voltage Adjustable Precision Shunt Regulator
Pin5
Package TypeDBV
Industry STD TermSOT-23
Package QTY3000
МаркировкаY3CI
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм)0.95
Max Height (мм)1.45
Initial Accuracy(Max)1.5 %
Iout/Iz(Max)15 мА
Iz for Regulation(Min)55 uA
Рабочий диапазон температурот -40 до 125,-40 до 85,0 до 70 C
Package GroupSOT-23
Package Size: mm2:W x L3SOT-23: 7 mm2: 2.37 x 2.92(SOT-23) PKG
Pin/Package3SOT-23, 3SOT-89, 3TO-92, 5SOT-23
Reference VoltageAdjustable
Temp Coeff(Max)138 ppm/ degree C
Temp Coeff(Typ)46 ppm/ degree C
VON/A В
VO Adj(Max)6 В
VO Adj(Min)1.24 В
  • Window Comparator Circuit
    PDF, 106 Кб, Файл опубликован: 1 фев 2018
  • Implementing a Buck Converter With the TPS23753A
    PDF, 454 Кб, Файл опубликован: 20 сен 2010
    The TPS23753A is intended for isolated applications and does not incorporate an internal voltage-regulation error amplifier. Due to its integration and features it may be advantageous to use the TPS23753A in non-isolated applications. This application report shows additional circuits necessary to implement a low-side switch buck converter using the TPS23753A.
  • Low Cost Bidirectional Current Sensing Using INA181
    PDF, 176 Кб, Файл опубликован: 28 июл 2017
  • Supplying TPS61200 With a Single Solar Cell (Rev. B)
    PDF, 129 Кб, Версия: B, Файл опубликован: 6 сен 2011
    This application report explains how to use the TPS61200 in combination with a single solar cell to charge a battery or storage device. A characteristic of solar cells is the internal resistance that can vary from less than 10 Ω up to more than 100 Ω. Therefore it is important to control the load placed on the solar cell to ensure a reliable start-up of the application. This report describes an a
  • Setting the shunt voltage on an adjustable shunt regulator
    PDF, 170 Кб, Файл опубликован: 1 сен 2011
  • Low-cost flyback solutions for 10-mW standby power
    PDF, 237 Кб, Файл опубликован: 22 янв 2014
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Analog and Mixed-Signal > Power Management > Voltage Reference > Shunt Voltage Reference
На английском языке: Datasheet Texas Instruments TLV431CDBVRE4
