Datasheet Texas Instruments THS4281DRG4 — Даташит
СерияTHS4281
МодельTHS4281DRG4
Очень маломощный высокоскоростной операционный усилитель с обратной связью по входному/выходному напряжению, 8-SOIC, от -40 до 85
THS4281 Very Low-Power, High-Speed, Rail-to-Rail Input and Output Voltage-Feedback Operational Amplifier datasheet
PDF, 2.8 Мб, Версия: B, Файл опубликован: 30 окт 2015
Package TypeD
Package QTY2500
Маркировка4281
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
2nd Harmonic69 dBc
3rd Harmonic76 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураBipolar,Voltage FB
BW @ Acl95 МГц
CMRR(Min)90 дБ
CMRR(Typ)107 дБ
GBW(Typ)95 МГц
Input Bias Current(Max)800000 pA
Iq per channel(Max)0.93 мА
Iq per channel(Typ)0.8 мА
Количество каналов1
Offset Drift(Typ)7 uV/C
Output Current(Typ)30 мА
Rail-to-RailIn,Out
Slew Rate(Typ)35 V/us
Total Supply Voltage(Max)16.5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)12.5 нВ/rtГц
Vn at Flatband(Typ)12.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2.5 мВ
  • Evaluation Modules & Boards: THS4281EVM
    THS4281 Evaluation Module
  • Low Power Input and Reference Driver Circuit for ADS8318 and ADS8319
    PDF, 1.5 Мб, Файл опубликован: 24 июн 2009
    The one size fits all approach to operational amplifiers is not effective. Every application has its own specific requirements that must be fulfilled. Appropriate selection of the op amp that drives an analog-to-digital converter (ADC) in a low-power application is a critical step. Most available low-power op amps trade off low-power features with other parameters such as bandwidth, settling t
  • Voltage Feedback vs. Current Feedback Op Amps
    PDF, 93 Кб, Файл опубликован: 30 ноя 1998
    This application report contrasts and compares the characteristics and capabilities of voltage and current feedback operational amplifiers. The report also points out the many similarities between the two versions.
  • Designing for low distortion with high-speed op amps
    PDF, 277 Кб, Файл опубликован: 2 мар 2005
На английском языке: Datasheet Texas Instruments THS4281DRG4
