Datasheet ТI LM335M/NOPB — Даташит
| Серия | LM335 |
| Модель | LM335M/NOPB |
Датчик температуры с аналоговым выходом, военный класс, герметичный и TO-92 8-SOIC от -40 до 100
LMx35, LMx35A Precision Temperature Sensors datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 10 фев 2015
- AN-295 A High Performance Industrial Weighing SystemPDF, 156 Кб, Файл опубликован: 10 май 2004
Application Note 295 A High Performance Industrial Weighing System - AN-298 Isolation Techniques for Signal Conditioning (Rev. B)PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
This application note provides information and examples of isolation techniques for signal conditioning. - IC Temp Sensor Provides Thermocouple Cold-Junction Compensation (Rev. B)PDF, 271 Кб, Версия: B, Файл опубликован: 23 апр 2013
Two circuits using the LM335 for thermocouple cold-junction compensation have been described. With asingle room temperature calibration, these circuits are accurate to В±3/4В°C over a 0В°C to 70В°C temperaturerange using J or K type thermocouples. In addition, a thermocouple amplifier using an LM335 for coldjunctioncompensation has been described for which worst case error can be as low as 1В°C p - AN-286 Applications of the LM392 Comparator Op Amp IC (Rev. B)PDF, 462 Кб, Версия: B, Файл опубликован: 26 апр 2013
This application note discusses the uses of the LM339 quad comparator and the LM324 op amp areamong the most widely used linear ICs today. The combination of low cost, single or dual supply operationand ease of use has contributed to the wide range of applications for these devices. - TO-92 Packing Options / Ordering Instructions (Rev. A)PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
- AN-272 Op Amp Booster Designs (Rev. B)PDF, 959 Кб, Версия: B, Файл опубликован: 23 апр 2013
This application report describes the output booster or post amplifier designs required to achieveneeded voltage or current gain in applications that require substantially greater output voltage swing orcurrent (or both) than IC amplifiers can deliver.
Серия: LM335 (14)
- Semiconductors > Space & High Reliability > Sensors > Temperature Sensor
