Datasheet Texas Instruments SN74HC595PWRE4 — Даташит
| Серия | SN74HC595 |
| Модель | SN74HC595PWRE4 |
8-битные сдвиговые регистры с выходными регистрами с 3 состояниями 16-TSSOP от -40 до 85
SNx4HC595 8-Bit Shift Registers With 3-State Output Registers datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 29 сен 2015
Купить SN74HC595PWRE4 на РадиоЛоцман.Цены — от 12 до 21 ₽12 предложений от 12 поставщиков Микросхема Счётчик, 8Bit Shift Registers With 3-State Output Registers 16-TSSOP -40℃ to 85℃ | |||
| SN74HC595PWRE4 Texas Instruments | 12 ₽ | ||
| SN74HC595PWRE4 Texas Instruments | по запросу | ||
| Pin | 16 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | HC595 |
| Width (мм) | 4.4 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| 3-State Output | Yes |
| F @ Nom Voltage(Max) | 28 Mhz |
| ICC @ Nom Voltage(Max) | 0.08 мА |
| Output Drive (IOL/IOH)(Max) | 7.8/-7.8 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | HC |
| VCC(Max) | 6 В |
| VCC(Min) | 2 В |
| Voltage(Nom) | 6 В |
| tpd @ Nom Voltage(Max) | 34 нс |
- Evaluation Modules & Boards: BOOSTXL-ULN2003
Dual Stepper Motor Driver BoosterPack featuring ULN2003 and CSD17571Q2 NexFETВ™
- Hardware Design Considerations for a Wireless LED based Display DesignPDF, 682 Кб, Файл опубликован: 11 июн 2014
Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
Серия: SN74HC595 (25)
- SN74HC595D SN74HC595DBR SN74HC595DBRE4 SN74HC595DBRG4 SN74HC595DE4 SN74HC595DG4 SN74HC595DR SN74HC595DRE4 SN74HC595DRG3 SN74HC595DRG4 SN74HC595DT SN74HC595DTE4 SN74HC595DW SN74HC595DWG4 SN74HC595DWR SN74HC595DWRE4 SN74HC595DWRG4 SN74HC595N SN74HC595NE4 SN74HC595NSR SN74HC595PW SN74HC595PWG4 SN74HC595PWR SN74HC595PWRE4 SN74HC595PWRG4
- Semiconductors > Logic > Flip-Flop/Latch/Register > Shift Register
