Datasheet Texas Instruments SN74HC595DT — Даташит
СерияSN74HC595
МодельSN74HC595DT
8-битные сдвиговые регистры с выходными регистрами с 3 состояниями 16-SOIC от -40 до 85
SNx4HC595 8-Bit Shift Registers With 3-State Output Registers datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 29 сен 2015
Pin16
Package TypeD
Package QTY250
CarrierSMALL T&R
МаркировкаHC595
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
3-State OutputYes
F @ Nom Voltage(Max)28 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)7.8/-7.8 мА
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)6 В
tpd @ Nom Voltage(Max)34 нс
  • Evaluation Modules & Boards: BOOSTXL-ULN2003
    Dual Stepper Motor Driver BoosterPack featuring ULN2003 and CSD17571Q2 NexFETВ™
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Semiconductors > Logic > Flip-Flop/Latch/Register > Shift Register
На английском языке: Datasheet Texas Instruments SN74HC595DT
