Datasheet Texas Instruments SN74HC595DBR — Даташит
СерияSN74HC595
МодельSN74HC595DBR
8-битные сдвиговые регистры с выходными регистрами с 3 состояниями 16-SSOP от -40 до 85
SNx4HC595 8-Bit Shift Registers With 3-State Output Registers datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 29 сен 2015
46 предложений от 18 поставщиков
Микросхема Регистр сдвига, TEXAS INSTRUMENTS SN74HC595DBR Shift Register, HC Family, 74HC595, Serial to Parallel, 1Element, 8Bit, SSOP, 16Pins
Зенер
Россия и страны ТС
SN74HC595DBR
от 14 ₽
SN74HC595DBR
от 33 ₽
SN74HC595DBR
SUV System
SN74HC595DBR
Pin16
Package TypeDB
Industry STD TermSSOP
Package QTY2000
МаркировкаHC595
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
3-State OutputYes
F @ Nom Voltage(Max)28 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)7.8/-7.8 мА
Package GroupSSOP
Package Size: mm2:W x L16SSOP: 48 mm2: 7.8 x 6.2(SSOP) PKG
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)6 В
tpd @ Nom Voltage(Max)34 нс
  • Evaluation Modules & Boards: BOOSTXL-ULN2003
    Dual Stepper Motor Driver BoosterPack featuring ULN2003 and CSD17571Q2 NexFETВ™
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Semiconductors > Logic > Flip-Flop/Latch/Register > Shift Register
На английском языке: Datasheet Texas Instruments SN74HC595DBR
